TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
Altera Cyclone II版 PCI开发套件在一个PCI板上提供了一个灵活低成本的FPGA开发平台。With a universal (3.3-V and 5-V) PCI edge connector, the PCI Development Kit, Cyclone II Edition plugs into any standard PCI or PCI-X slot. The kit includes both a hardware reference design and Windows software drivers to accelerate development. Users can perform transactions between the PCI interface and DDR2 memory within minutes of opening the box. The kit can be used as a development platform for 32-bit and 64-bit PCI, PCI-X, DDR2 SDRAM, and Altera Megafunction Partners Program (AMPPSM) partner intellectual property (IP) cores.The PCI Development Kit, Cyclone II Edition features:
- Cyclone II PCI Development Board
- Cyclone II EP2C35F672 FPGA
- Short-form universal PCI (3.3 or 5.0 V) card
- 32-bit or 64-bit PCI per the PCI Local Bus Specification Revision 2.3 at 33 or 66 MHz
- 100 MHz PCI-X Revision 2.0 mode 1
- Memory
- Two 64 Mbyte DDR2 SDRAM devices
- FPGA device configuration
- Switch-selectable on power-up, choose one of two serial configuration devices (EPCS64 devices). One device contains the pre-loaded factory default design, and the other device is for user-programming. Configuration data is downloaded via the USB-Blaster™ download cable.
- Flexible clocking options
- Socketed 100-MHz high-speed clock oscillator
- SMA connector clock input
- PCI edge connector clock input
- Switches and indicators
- Four user-definable push-button switches
- Eight-position user-definable dual in-line package (DIP) switch
- Eight user-definable LEDs
- Flexible power options
- PCI connector
- External power supply
- PCI Development Kit, Cyclone II Edition CD-ROM
- PCI-to-DDR2 Reference Design
- Cyclone II PCI Development Kit Application & Drivers
- PLD Applications PCI-X CORE CD-ROM
- PLD Applications PCI-X function for OpenCore® evaluation
- Reference designs&applications targeted to the Cyclone II PCI development board
- Quartus® II design software, including the SOPC Builder system development tool
- One-year license
- Windows platform only
- Jungo WinDriver Development Toolkit
- Cables&accessories
- USB Blaster download cable
- Power cable
- Complete documentation
