TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
Stratix® II DSP开发板符合RoHS认证,并提供了一个完整的DSP开发环境。The kit facilitates the entire design process from design conception through hardware implementation. The DSP Development Kit, Stratix II Professional Edition includes the Stratix II EP2S180 DSP development board, DSP Builder development tool, Quartus® II development software, MATLAB/Simulink evaluation software, evaluation intellectual property (IP) cores, system reference designs and labs, as well as power supplies, cables, and documentation.The DSP Development Kit, Stratix II Professional Edition features:
- Stratix II EP2S180 DSP development board
- Stratix II EP2S180F1020C3 device
- Analog I/O
- Two-channel, 12-bit, 125-million samples per second (MSPS) analog-to-digital (A/D)
- Two-channel, 14-bit, 165-MSPS digital-to-analog (D/A)
- VGA digital-to-analog converter (DAC)
- Stereo audio coder/decoder (CODEC), 96 KHz
- Digital I/O
- Connector for the Texas Instruments (TI) Evaluation Module (TI-EVM)
- Two 40-pin connectors for Analog Devices' A/D converter evaluation boards
- Mictor connector for Agilent and Tektronix logic analyzers
- RS-232 serial port
- 10/100 Ethernet physical layer/media access control (PHY/MAC) and RJ-45 jack
- Memory
- 32-Mbyte SDR SDRAM
- 16-Mbyte flash
- 1-Mbyte SRAM
- 16-Mbyte compact flash
- Power regulators
- LTC1778EGN: wide operating range, no RSENSE step-down controller
- LTC1326CS8: micropower precision triple supply monitor
- LT1085CM: 7.5-A, 5-A, 3-A low dropout positive adjustable regulators
- The MathWorks' MATLAB/Simulink evaluation software
- DSP Builder development tool
- Quartus II Design Kit Edition (DKE)
- Evaluation IP cores
- System reference designs and labs
- DSP Builder filtering design
- DSP Builder/SOPC Builder image processing reference design
- Fast Fourier transform (FFT) coprocessor reference design for TI's TMS320C6416 DSK
- Nios® II reference designs
- Cables and accessories
- USB-BlasterTM download cable
- Serial cable (RS-232)
- Power supply
- International power cords
Video input daughtercard features:
- Two composite video input channels using the TI TVP5146 ADC
- Support for NTSC/PAL
- 10-bit BT.656 Output
- Compatibility with expansion connector, standard on most Altera® development kits
- Included with Video Development Kit, Cyclone® II Edition
