查看: 422|回复: 0
Cyclone II EP2C70 DSP开发板
  • 签到天数: 11 天
    发表于 2012-9-27 15:11:53 | 显示全部楼层 |阅读模式
    Cyclone II EP2C70 DSP开发板符合RoHS认证,并提供了一个完整的DSP开发环境。The DSP Development Kit, Cyclone II Edition provides a low-cost hardware platform for developing high-performance DSP designs based on Altera® Cyclone II FPGAs.  The kit includes the Cyclone II DSP development board, DSP Builder development tool, Quartus® II development software, The MathWorks' MATLAB/Simulink evaluation software, evaluation intellectual property (IP) cores, and system reference designs and labs, as well as power supplies, cables, and documentation.The DSP Development Kit, Cyclone II Edition features:
    • Cyclone II EP2C70 DSP development board
      • Cyclone II EP2C70F672C6 device
    • Analog I/O
      • Two 14-bit analog-to-digital (A/D) converter channels with 125-million samples per second (MSPS)
      • Two 14-bit, 165-MSPS, 70 dB digital-to-analog (D/A) converters
      • One 24-bit RGB VGA adapter with a DB-15 connector
      • One Audio CODEC with input, output, and amplified output
    • External I/O
      • Mictor connector for hardware and software debugging
      • 3.3-V/5-V tolerant Altera expansion/prototype headers
      • One Texas Instruments Evaluation Module (TI-EVM) expansion connector to connect to the Spectrum Digital 'DSP Starter Kit (DSK) for the TMS320C6416', Revision E
    • Memory  subsystem
      • 256-Mbyte DDR2 SDRAM DIMM
      • 1-Mbyte synchronous SRAM (SSRAM)
      • Two EPCS64 devices
    • MATLAB/Simulink evaluation software
    • DSP Builder development tool
    • Quartus II Education Kit
    • Evaluation IP cores
    • System reference designs and labs
      • DSP Builder filtering design
      • DSP Builder/SOPC Builder image processing reference design
      • Fast Fourier transform (FFT) coprocessor reference design for Texas Instruments' TMS320C6416 DSK
      • Nios® II reference designs
      • DDR2 DIMM reference design
    • Cables and accessories
    • USB-BlasterTM download cable
    • Power supply
    • International power cords
    Video input daughtercard features:
    • Two composite video input channels using the TI TVP5146 ADC
    • Support for NTSC/PAL
    • 10-bit BT.656 output
    • Compatibility with expansion connector, standard on most Altera development kits and included with the Video Development Kit, Cyclone II Edition
    下载连接:
    Cyclone II EP2C70 DSP开发板参考指南
    Cyclone II EP2C70 DSP开发板入门指南
    Cyclone II EP2C70 DSP开发板原理图
    GMT+8, 2024-11-26 16:37 , Processed in 0.101176 second(s), 15 queries , MemCache On.
