TPS54314EVM 套件允许开发者评估TPS54314 同步降压型DC / DC转换器,集成3 A的MOSFET。The input voltage range is 3-6 V and the output voltage is 1.8 V. Other voltages are possible by replacing the IC with another fixed output version of the TPS5431x family. The TPS5431x is ideal for regulating the voltage in point of load applications from a 3.3 V or 5 V rail for high current DSPs, FPGAs, ASICs and microcontrollers.Please see the TPS54314EVM User's Guide document (SLLU036) for more information on module specifications and modification.
特性
Internal compensation for quick design
Oversized inductor pad for easy component modification
