查看: 617|回复: 0
视频输入子板
  • 签到天数: 11 天
    发表于 2012-9-27 10:39:49 | 显示全部楼层 |阅读模式
    Altera 启用复合视频的视频输入子板可以与任何配备标准扩展连接器的 Altera ® 或第三方合作伙伴 FPGA 开发板接口。 It is ideal for developing applications with the Video and Image Processing Solutions that need to perform any image processing. The daughtercard is included as part of the Video Development Kit, Cyclone® II Edition and it can be purchased as a separate item.Video Input Daughtercard Features
    • Two composite video input channels using the Texas Instruments (TI) TVP5146 ADC
    • Support for NTSC/PAL
    • 10-bit BT.656 output
    • Compatibility with expansion connector, standard on most Altera development kits
    GMT+8, 2024-11-26 16:30 , Processed in 0.108039 second(s), 15 queries , MemCache On.
