查看: 315|回复: 0
KIT34712EPEVBE 评估板
发表于 2012-9-26 11:26:40 | 显示全部楼层 |阅读模式
该评估套件突出了 MC34712EP (3.0 A 1.0  MHz完全集成DDR开关模式电源供应), 它是高度集成、高空间利用率、低成本,带集成N沟道功率MOSFET的单通道同步降压型开关稳压器。It is a high performance point-of-load (PoL) power supply with the ability to track an external reference voltage.
Features
  • 45 mΩ Integrated N-Channel Power MOSFETs
  • Input Voltage Operating Range from 3.0 V to 6.0 V
  • ±1 % Accurate Output Voltage, Ranging from 0.7 V to 1.35
  • ±1 % Accurate Buffered Reference Output Voltage
  • Programmable Switching Frequency Range from 200 kHz to 1.0 MHz with a default of 1.0 MHz
  • Over Current Limit and Short Circuit Protection
  • Thermal Shutdown
  • Output Overvoltage and Undervoltage Detection
  • Active Low Power Good Output Signal
  • Active Low Standby and Shutdown Inputs
Kit Contains
  • Assembled and tested evaluation board/module in anti-static bag.
  • CD-ROM containing:
    • Supporting Documentation for featured device (may include datasheet, user's guides, app notes...etc)
    • Schematic of evaluation board
    • Bill-of-Material for evaluation board
    • Instruction sheet for evaluation board
    • Software and configuration files (if applicable)
下载连接:
KIT34712EPEVBE 评估板用户指南
MC34712 数据手册
GMT+8, 2024-11-26 16:47 , Processed in 0.111873 second(s), 15 queries , MemCache On.
