查看: 361|回复: 0
KIT35XS3500EVBE 评估套件
发表于 2012-9-26 10:49:54 | 显示全部楼层 |阅读模式
KIT35XS3500EVBE 评估板支持MC35XS3500, 用于低压汽车和工业照明应用的设计。Its five low RDS(ON) MOSFETs (five 35mΩ) can control the high sides of five separate resistive loads (bulbs and LEDs). Programming, control, and diagnostics are accomplished using a 16-bit SPI interface (3.3V or 5.0V). Each output has its own PWM control via the SPI. The 35XS3500 has highly sophisticated failure mode handling to provide high availability of the outputs. Its multiphase control and output edge shaping improves electromagnetic compatibility (EMC) behavior.
Features
  • Penta 35mΩ high side switches
  • 16-bit SPI communication interface with daisy chain capability
  • Current sense output with SPI-programmable multiplex switch and Board Temperature Feedback
  • Digital diagnosis feature
  • PWM module with multiphase feature including prescaler
  • LEDs control including accurate current sensing and low duty-cycle capability
  • Fully protected switches
  • Over-current shutdown detection
  • Power net and reverse polarity protection
  • Low-power mode
  • Fail mode functions including autorestart feature
  • External smart power switch control including current recopy
Kit Contains
  • Assembled and tested evaluation board/module in anti-static bag.
  • CD-ROM containing:
    • Supporting Documentation for featured device (may include datasheet, user's guides, app notes...etc)
    • Schematic of evaluation board
    • Bill-of-Material for evaluation board
    • Instruction sheet for evaluation board
    • Software and configuration files (if applicable)
下载连接:
KIT35XS3500EVBE 评估套件用户指南
MC35XS3500 数据手册
GMT+8, 2024-11-26 16:43 , Processed in 0.109022 second(s), 15 queries , MemCache On.
