TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
FMC XM101 LVDS QSE板目的是向配置SP601,SP605和ML605的Xilinx开发板上的FMC连接器提供连接至LVDS引脚的通道。The FMC XM101 LVDS QSE Card provides a number of QSE headers and connectors which break out FPGA interface signals to and from the FMC HPC signal set.The FMC HPC signals are connected as length matched pairs to the QSE connectors. XM101 board users may loop back these pairs using the kit Samtec loopback cable, or create their own unique mezzanine board to plug onto the QSE connectors. Two Silicon Laboratories Si570 serial IIC bus re-programmable LVDS clock chips are available. The Si570 components are connected to an IIC bus switch. The bus switch component connects to the main IIC bus implemented in the FMC HPC interface, enabling the board’s FPGA to program the clock circuitry on the XM101. A 2-Kb serial IIC EEPROM is also connected to the IIC interface of the board, providing non-volatile storage.其中包含:
- FMC XM101 LVDS QSE Card
- Welcome letter
- One (1) Samtec EQDP-028-12.00-TEU-TED-1 28-pair 12 inch loopback cable
- Four (4) mounting screws
- Two (2) standoffs
- Board documentation, schematics, and PCB design files are available.
- Necessary equipment
- Small Phillips screwdriver to secure the FMC debug board to the carrier board
- PC with Internet access to download documentation, board files, and schematics
关键特性
- VITA 57.1 FMC HPC connector
- Single-ended signals from the carrier board, clocks, JTAG, power
- LVDS Pairs on QSE connectors
- QSE0 = LA00-LA16
- QSE1 = LA17-LA33
- QSE2 = HA00-HA23
- QSE3 = HB00-HB21
- Clocking
- SMA connectors
- Silicon Labs Si570 IIC serial bus re programmable LVDS clock source EEPROM
- 2 Kb EEPROM, IIC compatible electrically erasable programmable memory (EEPROM) with 2 Kb (256 bytes) of non-volatile storage.
- Power Good LEDS
- Power good LEDS for +12V, carrier to mezzanine (PG_C2M) and Vadjust/3.3Vb
下载连接:
FMC XM101 LVDS QSE Mezzanine Card用户指南 |
