查看: 313|回复: 0
X8 PCI Express Root FMC模块
  • 签到天数: 11 天
    发表于 2012-9-21 15:07:43 | 显示全部楼层 |阅读模式
    Vita 57提供了一个对于I/O中等模块的机械标准,这一标准引入了应允许前面板 IO IEEE 1101因子卡通过夹层板配置的方法。Vita 57 modules have fixed locations for serial/parallel IOs, clocks, Jtag signals, VCC, and GND. HiTech Global's Vita 57 modules can be plugged into any Vita 57 based boards.The FMC standard specifies Samtec’s SEARAY™ connector set. The VITA 57 SEAM/SEAF Series system provides up to 400 I/Os in a 40 x 10 configuration or 160 I/Os in a selectively loaded 40 x 10 configuration, in 8.5mm and 10mm stack heights.The FMC x8 PCI Express Gen 1/ Gen2  (HTG-FMC-PCIE-RC) is a FPGA Mezzanine Connector (FMC) daughter card with support for 8 lanes of PCI Express Root Complex (interfacing to total of 8 serial transceivers). Reference clock for the serial transceivers of the carrier board is provided through the module's super clock .Features:► x8 PCI Express Root- Provides access to total of 8 Serial Transceivers► Frequency Synthesizer (providing 100MHz - 250MHz clocking)► Clock Buffer► EEPROM► FMC Connector
    GMT+8, 2024-11-26 16:28 , Processed in 0.105077 second(s), 15 queries , MemCache On.
