TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
Vita 57提供了一个对于I/O中等模块的机械标准,这一标准引入了应允许前面板 IO IEEE 1101因子卡通过夹层板配置的方法。 Vita 57 modules have fixed locations for serial/parallel IOs, clocks, Jtag signals, VCC, and GND. HiTech Global's Vita 57 modules can be plugged into any Vita 57 based boards.The FMC standard specifies Samtec’s SEARAY™ connector set. The VITA 57 SEAM/SEAF Series system provides up to 400 I/Os in a 40 x 10 configuration or 160 I/Os in a selectively loaded 40 x 10 configuration, in 8.5mm and 10mm stack heights.The FMC Dual CX4 Module (HTG-FMC-2CX4) is a FPGA Mezzanine Connector (FMC) daughter card with two CX4 ports (interfacing to total of 8 serial transceivers). Reference clock for the serial transceivers of the carrier board is provided through the module's super clock .Features:► CX4 Connector (x2)- Provides access to total of 8 Serial Transceivers► Frequency Synthesizer (x2)► Clock Buffer► EEPROM► FMC Connector |
