TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
HTG-V6-PCIE系列专为高性能和高密度应用而设计,支持赛灵思Virtex-6 LX550T, LX240T, LX365T,SX475T或SX315T FPGA。为了扩展功能并提供更大的灵活性,HTG-V6-PCIE系列的设计可在x8/x4/x1的PCI Express第一代,第二代或单机模式下操作。The HTG-V6-PCIE series are supported by wide range of industry standard connectors and interfaces including ; 8-lane PCI Express Gen2, Gigabit Ethernet (10/100/1000), SMA (connected to two Virtex-6 GTX serial transceivers & external clock), USB 2.0/3.0 Host, USB 2.0/3.0 Device, SFP, DDR3, and Vita-57 FPGA Mezzanine Connectors.The expansion connectors provide access to up to 448 parallel IOs and 20 serial GTX transceivers of the on-board Virtex-6 device. The FMC connector can host off-the-shelf Vita-57 modules as well those developed by HiTech Global. Interfaces such as Single / Dual CX4, Dual / Quad SATA, Quad SFP, Dual / Quad SFP+ (20Gbps/40Gbps), and RJ45 are supported by the HiTech Global FMC modules. The HG-FMC-760 Virtex-6 FPGA module is also available for providing additional logic gates.To protect intellectual properties running on the Virtex-6 FPGA, the board is supported by an "IP Protection" chipset.Supported Virtex-6 devices: | XC6VLX240T | XC6VLX365T | XC6VLX550T | XC6VSX475T | XC6VSX315T | Slices | 37,680 | 56,880 | 85,920 | 74,400 | 49,200 | Logic Cells | 241,152 | 364,032 | 549,888 | 476,160 | 314,880 | CLB Flip-Flops | 301,440 | 455,040 | 687,360 | 595,200 | 393,600 | Maximum Distributed RAM (Kbits) | 3,650 | 4,130 | 6,200 | 7,640 | 5,090 | Block RAM/FIFO w/ ECC (36Kbits each) | 416 | 416 | 632 | 1,064 | 704 | Total Block RAM (Kbits) | 14,976 | 14,976 | 22,752 | 38,304 | 25,344 | Mixed Mode Clock Managers (MMCM) | 12 | 12 | 18 | 18 | 12 | Maximum Single-Ended I/O | 720 | 720 | 1200 | 840 | 720 | Maximum Differential I/O Pairs | 360 | 360 | 600 | 420 | 360 | DSP48E1 Slices | 768 | 576 | 864 | 2,016 | 1,344 | PCI Express® Interface Blocks | 2 | 2 | 2 | 2 | 2 | 10/100/1000 Ethernet MAC Blocks | 4 | 4 | 4 | 4 | 4 | GTX Low-Power Transceivers | 24 | 24 | 36 | 36 | 24 | Commercial | -L1, -1, -2, -3 | -L1, -1, -2, -3 | -L1, -1, -2 | -L1, -1, -2 | -L1, -1, -2, -3 | Configuration Memory (Mbits) | 70.4 | 91.6 | 137.4 | 149.4 | 99.6 | Features:▪ Xilinx Virtex 6 LX550T, LX365T, LX240T, SX475T, or SX315T in different speed grades▪ x8 PCI Express Gen 2 Edge Connector▪ PCI Express Jitter Attenuator for cleaning PC clock and generating different PCIe clocks (100MHz, 250MHz, etc.)▪ DDR3 SO-DIMM (up to 8GB)▪ One USB 2.0 & 3.0 Host port▪ One USB 2.0 & 3.0 Device port▪ Two SFP ports (4 additional SFP and two SFP+ connectors are available through HTG-FMC-4SFP-4SATA and HTG-FMC-SFP-PLUS modules)▪ Four SMA connectors for one GTX serial transceiver port (8 additional SMA ports are available through HTG-FMC-8SMA module)▪ Two SMA connectors for external differential clock▪ Two 10/100/1000 Ethernet ports with SGMII, RGMII, and GMII support using Marvell 88E111 PHY (4 additional SGMII ports are available through HTG-FMC-RJ45 module)▪ FMC Vita 57 compliant Connectors with :- Connecter #1:160 Single Ended IOs (or 80 LVDS), & ten Data-Rate-Adjustable GTX transceivers with the LX550T, LX365T, LX240T, SX475T, or SX315T models- Connecter #2:126 Single Ended IOs (or 63 LVDS) with the LX365T, LX240T, or SX315T models160 Single Ended IOs (or 80 LVDS), & ten Data-Rate-Adjustable GTX transceivers with the LX550 and SX475 models▪ Auxiliary FMC Super Clock for board-to-board communication▪ Samtec QSE High-speed connectors with 32 pairs of LVDS IOs▪ IP Protection Chipset▪ Power Management Bus for all voltage rails▪ Size: 9.5" x 4.25"▪ Support for both PCI Express and stand alone operation modes▪ Standard ATX and wall power supply connectors |
