TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
ADC512扩展板给系统开发者提供了直接与嵌入式处理模式的FPGA开发板连接的模拟输入端口。As the ADC512 is part of a range of modular I/O solutions conforming to the VITA 57 FMC standard, developers can change I/O formats by changing relatively low cost modules while the more expensive host processing cards remain the same. This allows developers to reuse host firmware and software elements from previous projects thus reducing cost, development times and risk. Typical DSP applications for this module include Signal Intelligence (SIGINT), Electronic Counter Measures (ECM), and Radar. 特性:
- Dual Channel 3 GSPS 8-bit ADC FPGA Mezzanine Card (FMC)
- Dual National Semi ADC083000, 8-bit ADCs
- Up to 3 GSPS
- AC coupled analog input bandwidth >2.25GHz
- Multi-board synchronization capability
- FMC/VITA 57 (draft) form factor
- FusionXF support
- Air and conduction-cooled variants
