FMC204是一个四通道的数模转换扩展板,FMC204为16 位D/A启用1 GSP 的最大速率采样提供了四个通道。The sample clock can be supplied externally through a coax connection or supplied by an internal clock source (optionally locked to an external reference). Additionally a trigger input for customized sampling control is available. The FMC204 daughter card is mechanically and electrically compliant to FMC standard (ANSI/VITA 57.1). The card has a high-pin count (HPC) connector, front panel I/O, and can be used in a conduction cooled environment as well as a conventionally (air) cooled environment. The FMC204 allows flexible control on clock source, sampling frequency, and calibration through an I2C communication bus. The FMC204 card is equipped with power supply and temperature monitoring with several power-down modes to switch off unused functions, reducing system level power and heat, well suited for software defined radio (SDR), battery or other low power source applications. This is ideal for applications such as airborne where power demand effects mission range and on-station mission time.Features
4-Channels 16-bit 1 Gsps D/A conversion Mode
VITA 57.1-2010 compliant
Conduction Cooled – Standard Option
LVDS data format
Single ended AC-coupled analog output
Clock Source, Sampling Frequency, and Calibration through an I2C communication bus
