TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
CoreCommander开发板是在行业中独树一帜,采用了Altera公司的Cyclone III FPGA,为几乎所有的嵌入式设计提供了足够多的空间。This flexible board comes with a suite of SLS IP Cores, drivers, and application software. Delivered as a complete package, the board and soft content ensures quick and easy implementation of industry leading cores with reduced risk AND at a very low cost.Once you determine that an SLS IP Core will meet your design requirement - purchasing the complete core is easy with flexible licensing options.CoreCommander can also host several other Altera created IP cores and with a very little effort host IP cores from other manufacturers and developers. SLS can work with you to compile and port your designs to this exciting development board.Finally, CoreCommander is available as an OEM module for companies who wish to highlight their IP cores and software and create industry leading design kits.特性:
- Low-power consumption Altera Cyclone lll EP3C25F256 FPGA
- 16-bit Memory interface
- 1 Gbit NAND Flash (Hardware Support up to 4 Gbit)
- 256 Mbit SDRAM
- 8 Mbit SPI Serial Flash Memory
- USB 2.0 ULPI/OTG Interface
- USB 2.0 ULPI/Host Interface
- 4 bit parallel SD Card interface
- 36 General purpose I/Os
- JTAG/Active Serial FPGA Programming Mode Selection
- M25P16 for configuration
- Two user LEDs
- 1.7" 128x160 pixel TFT LCD with GRAM (on User Interface Board)
- Six user programmable and one reset push-button switches (on User Interface Board)
