查看: 269|回复: 0
Cyclone III EP3C25 USB Blaster套件
  • 签到天数: 11 天
    发表于 2012-9-18 15:32:09 | 显示全部楼层 |阅读模式
    CMCS002模块实现FPGA的逻辑功能和Altera的Nios II处理器在尽可能小的外形尺寸下的运行。 Niomite为支持小尺寸的基于FPGA的控制器提供了以下器件:Altera EP3C25 FPGA512K X 8 SRAMEP1S16 FPGA serial loader (FPGA and Nios II boot)USB 2.0 Peripheral Port (low/full speed operation)The CMCS002 module also supports the specification (master or slave standard card, 128 pin), and can interface with other modules designed to that specification.  The CMCS002 kit includes an FPGA programmer and power supply, and provides all the hardware items which are necessary to start designing with and evaluating the powerful features of Altera® Cyclone III FPGA devices.Module Details :Altera® EP3C25 FPGA, in –C8 speed grade in 256 pin BGA package.Separate programming ports (ASMI flash interface and JTAG interface).Reset and voltage monitor IC which provides 400mS reset pulse.Reset push-button switch.109 input/output pins available on stack-through header.3 discrete indicator LED (red, yellow, green).Clock oscillator (25 MHz).compatible design.  Populated with stack-through connector.EPCS16 (16Mbit) serial flash for FPGA configuration and Nios II software.512K x 8 bit (4Mbit) SRAM for Nios II program execution and dynamic data storage.USB 2.0 full speed port (FT232RL).Quartus II Starter Design :Created using Quartus II ver. 9.0 SP1.Nios II processor defined.All module pins are defined in top level schematic project file.Memory test with results indicated to LED.FPGA load from EPCS16.Kit Package Contents :CMCS002 Cyclone III EP3C25 module.Wall mount 3.3VDC/2A switching supply.Altera® USB Blaster FPGA programmer.
    GMT+8, 2024-11-26 17:40 , Processed in 0.105104 second(s), 15 queries , MemCache On.
