查看: 296|回复: 0
Cyclone II "Quicgate" EP2C8模块
  • 签到天数: 11 天
    发表于 2012-9-18 14:20:32 | 显示全部楼层 |阅读模式
    Quicgate模块实现FPGA的逻辑功能和Altera的Nios II处理器在尽可能小的外形尺寸下的运行。 Niomite为支持小尺寸的基于FPGA的控制器提供了以下器件:256K X 16 SRAMEP1S4 FPGA serial loader (FPGA and Nios II boot)4 Mbit serial FlashRS-232 linkQuicgate modules also supports the specification (master or slave standard card, 128 pin), and can interface with other modules designed to that specification.  The Quicgate kit includes an FPGA programmer and power supply, and provides all the hardware items which are necessary to start designing with and evaluating the powerful features of Altera® Cyclone II FPGA devices.Module Details :Altera® EP2C8 Cyclone II FPGA, in –C8 speed grade.Separate programming ports (ASMI flash interface and JTAG interface).Reset and voltage monitor IC which provides 400mS reset pulse.Reset push-button switch.110 input/output pins available.3 discrete indicator LED (red, yellow, green).Clock oscillator (25 MHz).compatible design.EPCS4 (4Mbit) serial flash for FPGA configuration (and Nios II software).256K x 16 bit (4Mbit) SRAM for Nios II program execution and dynamic data storage.One RS-232 interface.4 Mbit serial flash for data storage.Quartus II Starter Design  :Created using Quartus II ver. 7.2 SP3.Nios II processor defined.All module pins are defined in top level schematic project file.Memory test with results indicated to LED.FPGA load from EPCS4.Serial Flash device diagnostic.RS-232 port test.Kit Package Contents :Quicgate Cyclone II EP2C8 module.Wall mount 3.3VDC/2A switching supply.Altera USB Blaster FPGA programmer.
    下载连接:
    Cyclone II "Quicgate" EP2C8模块用户指南
    Cyclone II "Quicgate" EP2C8模块原理图
    GMT+8, 2024-11-26 17:35 , Processed in 0.136744 second(s), 15 queries , MemCache On.
