查看: 235|回复: 0
C3 FPGA开发板
  • 签到天数: 11 天
    发表于 2012-9-18 11:22:44 | 显示全部楼层 |阅读模式
    C3 FPGA开发板是设计用于与新开发的DRK套件接口。该板提供了一个快速简单的原型和设计验证的平台。It can be powered stand alone and accessed through an RS232 port. The C3 FPGA comes with an onboard configuration PROM to retain the FPGA settings, an RS232 level shifter, voltage monitor, oscillator, buttons, and LEDs. There is a prototyping area on the board for user circuits and FPGA pins are accessible through connectors and clearly labeled test points. The connectors are designed to mate with other CEPD designed daughter boards. All software tools necessary for completing designs are available free from the Altera website. Altera programmer not included. Power supply included.特性:
    • Cyclone III® FPGA - EP3C16F484C8N
    • Configuration PROM
    • Crystal oscillator
    • On board voltage regulators and voltage monitor
    • RS232 level shifter and DB9 serial port
    • FPGA code defined buttons
    • FPGA code defined LEDs
    • Prototyping area for user circuits
    • FPGA pins accessible to the user through connectors and test points
    • Free software tools available for download from Altera
    • Full documentation with schematic
    • Example FPGA design for board verification
    • Connects directly to other CEPD daughter cards
    GMT+8, 2024-11-26 17:48 , Processed in 0.109445 second(s), 15 queries , MemCache On.
