查看: 328|回复: 0
C3 DRK 开发板
  • 签到天数: 11 天
    发表于 2012-9-18 11:00:05 | 显示全部楼层 |阅读模式
    C3 DRK 开发板目标是在开发和测试中帮助算法和信号处理的应用,包括:
    • 数字音频、调制/解调的开发;
    • 软件定义的无线电
    • 高速数据接收和信号处理
    • 音频数据接收和信号处理
    The system combines a PCI card, an FPGA signal processing card, and a down converting digital radio card. All three cards have connectors allowing them to stack, forming a digital radio system.  The kit will operate in standalone mode or the PCI card can be attached to a computer.The standard configuration for the digital radio card is the 75MHz to 150MHz band.  The digital radio card is capable of transmitting and receiving RF signals. Filters, Low Noise Amplifiers, and mixers are socket-ed to simplify frequency changes. The card includes a frequency synthesizer LO and mixers for up and down conversion for transmitting and receiving.  The card utilizes a 13-bit, 210 million samples per second (MSPS) analog-to-digital converter (ADC), a 14-bit, 400 MSPS digital-to-analog converter (DAC) and an audio codec. The acquired signals are sampled and then digitally processed by the customizable Altera Cyclone III®, 180,000 gate FPGA card. Users may customize the FPGA to implement their own algorithms. The FPGA card comes with a JTAG programming connector and a configuration PROM to retain the FPGA settings. The PCI card provides interfaces for the FPGA card to a computer PCI bus, RS232, and user push buttons. A Digital Radio reference FPGA design example and full documentation are included.Features : Analog Input Path
    • 13bit ADC 210MSPS
    Analog Output Path
    • 14bit DAC 200MSPS
    Synthesizer
    • 600MHz Synthesizer
    • 75MHz to 150MHz VCO(Voltage Controlled Oscillator)
    • High precision, VC-TCXO(Voltage Controlled Temperature Compensated Crystal Oscillator)
    CODEC
    • 16bit CODEC Sampling Frequency 26kHz, Dynamic Range 88dB
    • Input - 3.5mm stereo jack (line level or 3.3V biased electret mic)
    • Output - 3.5mm mono jack (line level)
    General
    • Externally powered with 12VDC
    • On board voltage regulators
    • Hardware tune-able antenna filter with an SMA jack
    • Filters are socket-ed for easy frequency changes
    • Filter bypass switches on board
    • TX/RX controlled with a &quotush to talk" digital input
    • Prototyping area for user circuits
    • Full documentation with schematic
    • Reference FPGA Digital Radio design for board verification
    下载连接:
    C3 DRK 数据手册
    GMT+8, 2024-11-26 17:25 , Processed in 0.104313 second(s), 15 queries , MemCache On.
