查看: 356|回复: 0
R0K572630D001BR开发板
发表于 2012-9-11 14:36:49 | 显示全部楼层 |阅读模式
SH7263 音频接口、存储卡接口和USB连接器都是标准的,所以它适合用于音频系统开发。Product Information
CPUType Code of CPU BoardOn-board MemoryCPU MountingSH7263R0K572630D001BRSDRAM (16MB), NOR flash memory (4MB),NAND flash memory (512MB)Chip mounted
R0K572630D001BR Features
The SH7263, the audio interface, memory card interface, and USB connector are standard built in, so it is suitable for predevelopment of audio system.
All of the SH7263 chip I/O ports are connected to the extension connector of the board, allowing for easy hardware expansion.
The development environment such as the application note and sample program of SH7263 chip, necessary for advanced development, is provided.
The board comes standard with the H-UDI connector (14-pin type/36-pin type) to which the Renesas emulator E10A-USB can be connected.
R0K572630D001BR Specifications
ItemSpecificationCPU
  • SH7263- Input (XIN) clock : 16.67MHz- Bus clock: Maximum 66.67MHz- CPU clock: Maximum 200MHz
  • On-chip Memory- RAM:64K-byte (High speed), 16K-byte(For data retention)
External Memory
  • Flash memory:4MB
  • NAND flash memory :512MB
  • SDRAM:16MB
Connector
  • USB connector (series A receptacle)
  • Line-out pin jack (4 pcs)
  • Optical connector (1 pc)
  • Microphone-in pin jack (1 pc)
  • 2-pin MIL pitch-hole (for RCAN)
  • Serial port connector (D-sub 9-pin)
  • H-UDI connector (14-pin/36-pin type)
  • Extension board connector (50-pin/140-pin)
  • SH7263 user I/O connector (Not mounted)
  • SSI/Serial connector
  • TFT panel connector
  • TFT panel touch panel connector
  • Serial connector
LED
  • Power LED (1pc.)
  • User LED (4 pcs.)
Switch
  • Reset, NMI, IRQ switch
  • DIP switch for system setting (4-pole x 1)
  • User DIP switch (4-pole x 1)
  • SH7263 key scan switch (3x4=12pcs.)
Board Dimensions
  • Dimensions: 160mm x 190mm
  • Mounting form : 6-layer, double-side mounted
  • Board configuration:1 board
Included Accessories
    • CD-ROM (User's Manual, Installation Manual, Sample Software)
    • Release Note
    • Power supply cable
R0K572630D001BR Appearance
Top view of the component sideTop view of the solder side
GMT+8, 2024-11-26 19:46 , Processed in 0.118498 second(s), 15 queries , MemCache On.
