查看: 277|回复: 0
EZ-0007套件
发表于 2012-9-11 09:38:10 | 显示全部楼层 |阅读模式
EZ-0007是一个评估板,装有用于LED的恒流驱动 IC uPD168804 .The board has a built-in high-brightness LED and power regulator, and is able to evaluate lighting by connecting a single 12 V power source. A connector capable of PWM signal input can also be used to connect to an EZ-0006 or other board, and evaluate dimming using a microcontroller.Features
  • Built-in uPD168804 constant-current driver IC for LEDs
  • Built-in our general-purpose products(Power MOSFET uPA2756GR、static electricity protection Diode NNCD36J、Voltage Regulator uPC2905A)
  • 350mA Built-in four-color LED: R, G, B, and W
  • Support for Applilet EZ for HCD automated software generation tool
  • PWM dimming from microcontroller
  • Note:Support for Applilet EZ for HCD is only available in conjunction with EZ-0006.
GMT+8, 2024-11-26 19:40 , Processed in 0.118436 second(s), 15 queries , MemCache On.
