查看: 260|回复: 0
EZ-0006套件
发表于 2012-9-11 09:33:29 | 显示全部楼层 |阅读模式
EZ-0006是一个 使用78K0/IA2的PWM评估板 。The board is equipped with connectors enabling connection to communication interfaces, analog signal-input pad, and the uPD168804 Buck converter HBLED Evaluation Board (EZ-0007). Connecting to an EZ-0007 board enables high-resolution dimming of a 4-channel LED. Features
  • High-speed/high resolution PWM evaluation of 78K0/IA2
  • Support for two different communication featuresALI communication and DMX512 communication
  • On-chip debugging using USB cable
  • Support for Applilet EZ for HCD automated software generation tool
  • Note:Support for Applilet EZ for HCD is only available in conjunction with EZ-0007.
GMT+8, 2025-2-17 09:39 , Processed in 0.104193 second(s), 15 queries , MemCache On.
