查看: 256|回复: 0
QB-78F0730-TB开发板
发表于 2012-9-10 14:17:06 | 显示全部楼层 |阅读模式
作为与片上调试仿真器 E1或 MINICUBE2 连接的CPU开发板,该产品实现了目标MCU的简单评估Features
  • Built-in μPD78F0730MC MCU
  • Operatable at high speed with the 16 MHz system clock (oscillator equipped) (when supplied with 4.0 to 5.5V)
  • Equipped with universal area (2.54mm pitch)
  • Both flash memory programming and on-chip debugging supported (OCD1A/OCD1B pins)
  • MCU pins assigned to the peripheral board and connector for higher expandability
  • Lead-free (Pb-free)
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接:
QB-78F0730-TB用户指南
GMT+8, 2024-11-26 19:25 , Processed in 0.110651 second(s), 15 queries , MemCache On.
