查看: 250|回复: 0
QB-78K0RLG3M-TB开发板
发表于 2012-9-10 09:35:03 | 显示全部楼层 |阅读模式
作为与片上调试仿真器 E1或 MINICUBE2 连接的CPU开发板,该产品实现了目标MCU的简单评估Features
  • Incorporates 78K0R/LG3-M (μPD78F8070GC).
  • A 20 MHz resonator mounted as main clock, high-speed operation enabled (@ 2.7 to 3.6V)
  • Equipped with universal area (2.54 mm pitch).
  • Supports both flash memory programming and on-chip debugging (using TOOL0/TOOL1 pins)
  • Highly extendable; peripheral board connectors are equipped with microcontroller pins.
  • Lead-free (Pb-free) product.
下载连接:
QB-78K0RLG3M-TB用户指南
GMT+8, 2024-11-26 19:23 , Processed in 0.119397 second(s), 15 queries , MemCache On.
