20 MHz oscillator used for the main clock and High-speed operation (when supplied with 2.7 to 5.5 V)
Both flash memory programming and on-chip debugging supported (TOOL0/TOOL1 pins)
Simple testing possible with 2 LEDs and 1 SW
Equipped with universal area (2.54mm pitch)
MCU pins assigned to the peripheral board and connector for higher expandability
Lead-free (Pb-free)
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接: QB-78K0RKG3C-TB用户指南
