查看: 281|回复: 0
QB-78K0RIE3-TB开发板
发表于 2012-9-7 14:36:01 | 显示全部楼层 |阅读模式
作为与片上调试仿真器 E1或 MINICUBE2 连接的CPU开发板,该产品实现了目标MCU的简单评估Features
  • Built-in78K0R/IE3 (μPD78F1235GB) MCU with 40 MHz internal high-speed oscillator.
  • 20 MHz oscillator used for the main clock and High-speed operation (when supplied with 2.7 to 5.5 V)
  • Both flash memory programming and on-chip debugging supported (TOOL0/TOOL1 pins)
  • Simple testing possible with 2 LEDs and 1 SW
  • Equipped with universal area (2.54mm pitch)
  • MCU pins assigned to the peripheral board and connector for higher expandability
  • Lead-free (Pb-free)
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接:
QB-78K0RIE3-TB用户指南
GMT+8, 2024-11-26 19:37 , Processed in 0.107762 second(s), 15 queries , MemCache On.
