查看: 250|回复: 0
QB-R5F10RLC-TB开发板
发表于 2012-9-7 14:05:46 | 显示全部楼层 |阅读模式
作为与片上调试仿真器 E1 连接的CPU开发板,该产品实现了目标MCU的简单评估Features
  • Incorporates RL78/L12 (R5F10RLCAFB).
  • A 20 MHz resonator mounted as main clock, high-speed operation enabled (@ 2.7 to 5.5 V).
  • Equipped with universal area (2.54 mm pitch).
  • Supports both flash memory programming and on-chip debugging (using TOOL0 pin).
  • Highly extendable; peripheral board connectors are equipped with microcontroller pins.
  • Lead-free (Pb-free) product.
下载连接:
QB-R5F10RLC-TB用户指南
GMT+8, 2024-11-26 19:58 , Processed in 0.113745 second(s), 15 queries , MemCache On.
