查看: 263|回复: 0
QB-V850ESKG2-TB开发板
发表于 2012-9-7 11:12:28 | 显示全部楼层 |阅读模式
作为与片上调试仿真器 E1或 MINICUBE2 连接的CPU开发板,该产品实现了目标MCU的简单评估Features
  • Built-in V850ES/KG2 (μPD70F3732GC) MCU with 256KB flash memory and 16 KB RAM.
  • Operation of 20 MHz system clock (5 MHz oscillator used).
  • Equipped with maximum 84 I/O ports
  • Both flash memory programming and on-chip debugging supported (SI00/SO00/SCK00/PCM0 pins)
  • Simple testing possible with 2 LEDs and 1 SW
  • Equipped with universal area (2.54mm pitch)
  • MCU pins assigned to the peripheral board and connector for higher expandability
  • Lead-free (Pb-free)
  • Operating voltage 2.7V-5.5V, operatable on 2 batteries
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接:
QB-V850ESKG2-TB用户指南
GMT+8, 2024-11-26 19:37 , Processed in 0.128253 second(s), 15 queries , MemCache On.
