查看: 239|回复: 0
QB-V850ESJJ3-TB开发板
发表于 2012-9-7 10:50:11 | 显示全部楼层 |阅读模式
作为与片上调试仿真器 E1或 MINICUBE2 连接的CPU开发板,该产品实现了目标MCU的简单评估Features
  • Built-in V850ES/JJ3 (μPD70F3746GJ) MCU with flash memory 384KB and RAM 32KB
  • High-speed operation of 32 MHz system clock (4 MHz oscillator used)
  • Equipped with universal area (2.54mm pitch)
  • Both flash memory programming and on-chip debugging supported (SIB0/SOB0/SCKB0/PCM0 pins)
  • MCU pins assigned to the peripheral board and connector for higher expandability
  • Lead-free (Pb-free)
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接:
QB-V850ESJJ3-TB用户指南
GMT+8, 2024-11-26 19:36 , Processed in 0.112787 second(s), 15 queries , MemCache On.
