High-speed operation of 48 MHz system clock (6 MHz oscillator used).
Both flash memory programming and on-chip debugging supported (SIF3/SOF3/P913 pins)
Equipped with universal area (2.54mm pitch)
MCU pins assigned to the peripheral board and connector for higher expandability
Lead-free (Pb-free)
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接: QB-V850ESJG3U-TB用户指南
