Built-in V850ES/JG2 (μPD70F3717GC) MCU with 384KB flash memory and 32 KB RAM.
High-speed operation of 20 MHz system clock (5 MHz oscillator used).
Equipped with maximum 84 I/O ports
Both flash memory programming and on-chip debugging supported (SIB0/SOB0/SCKB0/PCM0 pins)
Simple testing possible with 2 LEDs and 1 SW
Equipped with universal area (2.54mm pitch)
MCU pins assigned to the peripheral board and connector for higher expandability
Lead-free (Pb-free)
Operating voltage 3.0V-3.6V, operatable on 2 batteries
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接: QB-V850ESJG2-TB用户指南
