查看: 292|回复: 0
QB-V850EIH4H-TB开发板
发表于 2012-9-6 10:37:59 | 显示全部楼层 |阅读模式
作为与片上调试仿真器 E1或 MINICUBE2 连接的CPU开发板,该产品实现了目标MCU的简单评估。Features
  • Built-in V850E/IH4-H(μPD70F3924GF) MCU
  • High-speed operation of maximum 100 MHz (12.5 MHz oscillator used for the main clock ) when supplied with 3.5 to 5.5 V.
  • Equipped with universal area (2.54mm pitch)
  • Both flash memory programming and on-chip debugging supported (SIF0/SOF0/SCKF0/P44 pins)
  • MCU pins assigned to the peripheral board and connector for higher expandability
  • Lead-free (Pb-free)
Connection with The E1 Emulator
The CPU board is provided with a 16-pin/2.54mm pitch connector for the connection with MINICUBE2. Connecting it to the E1 emulator, whose user interface cable has a 14-pin/2.54mm pitch connector, requires the optional adapter QB-F14T16-01
下载连接:
QB-V850EIH4H-TB用户指南
GMT+8, 2024-11-26 21:17 , Processed in 0.111924 second(s), 15 queries , MemCache On.
