M3A-HS60G50 是一个CPU开发板,用于评估SH7206芯片的性能。It may be used as the development platform for various products, for trial manufacture of microcomputer systems, or for developing and evaluating application software.Notice | This product does not include power supply and development tools. It is necessary to prepare following items separately.- Power supply (5V, 1.5A min)- C/C++ Compiler package for SuperH RISC engine family- E10A-USB | Product Information
CPUType Code of CPU BoardCPU MountingSH7206M3A-HS60G50Mounted on board directory
Features
| M3A-HS60G50 is the CPU board mounting SH7206 (SH-2A core, 200MHz operating clock frequency). | | External flash memory and SDRAM are mounted on board. | | It is easy for evaluation of on-chip peripheral I/O and system extension. | | All the peripheral I/O and external bus pins are connected to an extension connector (*1) so that it is possible to develop the extension board for a variety of uses. In addition, it is easy to do the timing evaluation by using measuring instrument. | | For prototype manufacturing of motor control application | | Only signal lines especially deeply related to the motor control among I/O pins of CPU are collected in the user I/O connector (*2) , so that it is easy to develop prototype manufacturing for the motor control application. | | The H-UDI connector to which Renesas emulator E10A-USB (*3) can be connected is mounted on board. | | *1: Not mounted*2: Connector, which can be connected to the user I/O connector, is not mounted*3: Optional item | Specifications
ItemSpecificationCPU
- SH7206 (SH-2A CPU Core)- Input (XIN) clock : 16.67 MHz- Bus clock : 66.67MHz, max- CPU clock : 200MHz, max
On -board Memory
- Flash memory : 4 Mbytes (M5M29KT331AVP)** Data-bus width fixed to 16-bit.
- SDRAM : 32MB (max) *Data bus width is selectable- When 16-bit bus is selected : 16MB- When 32-bit bus is selected : 32MB
Connector
- H-UDI connector (36-pin) with AUD (Trace) function.
- Serial port connector (RS-232C, D-sub, 9-pins)
- Extension connector (* not mounted)
- User I/O connector ( for motor control ) (* not mounted)
LED
- Power LED (1 pc.)
- User LED (7 pcs.)
Switch
- Reset, NMI and MRES switches
- System setup DIP switch (1 pc., 5 poles)
- User DIP switch (1 pc., 4 poles)
Board Dimensions
- Dimensions : 100mm x 100mm
- Mounting form : 4-layer, double-side mounted
- Board configuration : 1 board
Included Accessories
- CD-ROM (User's Manual, Installation Manual, Sample Programs)
- Release Note
- Power supply cable (5V)Notice : It is necessary to prepare following items separately.- Power supply (5V, 1.5A min)- C/C++ Compiler package for SuperH RISC engine family- E10A-USB
Product Appearance
下载连接:
M3A-HS60 用户指南 |
