查看: 277|回复: 0
M3A-ZA53开发板
发表于 2012-9-5 10:21:02 | 显示全部楼层 |阅读模式
可以在SuperH解决方案Engine(MS7727RP02) 上评估 USB ASSP。
Feature
  • It is possible to do evaluation of the USB ASSP by connecting CN1 of M3A-ZA53 to the Expansion slot of the SuperH Solution Engine(MS7727RP02:CN1 connector) and connecting CN2 and CN3 of M3A-ZA53 to CN2 and CN3 of the USB ASSP Utility Board .
  • M3A-ZA53 has connector pattern for evaluation of split bus.
  • The SuperH Solution Engine of below is available to use.
    • SuperH Solution Engine Light (MS7727RP02)
    • Processer Target Systems (SuperH Solution Engine )
  • The USB ASSP Utility Board of below is available to use.
    • M66291GP Utility Board (M3A-0032)
    • M66591GP Utility Board (M3A-0037G01)
    • M66592FP Utility Board (M3A-0038G01)
    • M66596FP Utility Board (M3A-0039)
下载连接:
M3A-ZA53使用说明
GMT+8, 2024-11-26 21:48 , Processed in 0.116330 second(s), 15 queries , MemCache On.
