M3A-HS87G50用于评估SH7286 MCU的特性和功能。As the development platform, it allows test production of user system, development and evaluation of the application software.CPUCPU board part numberMemoryCPU mountingSH7286M3A-HS87G50N/Asurface-mounted
| Mounts the SH7286 MCU (SH-2A core, 100 MHz, 176-pin) | | Includes a USB Series-B receptacle to develop and evaluate software using the SH7286 on-chip USB function | | module in full-speed | | SH7286 data bus, address bus and on-chip peripheral pins are all connected to through-holes for expansion | | connectors on this board to allow for timing analysis with peripherals that use measurement instruments. | | H-UDI port connectors (36-pin/14-pin) is provided to connect the Renesas E10A-USB emulator | | Note1) The E10A-USB emulator is not included. |
M3A-HS87G50 Specifications
| ItemSpecificationCPU
- SH7286- Input (XIN) clock: 12.5 MHz- CPU clock: 100 MHz (max.)- Bus clock: 50 MHz (max.)- On-chip memory
- On-chip MemoryFlash memory: 1024KBRAM: 32KB
Memory
- SDRAM: 16 MB x 2 (optional)
- EEPROM: 128 Kbit (optional)
Connectors
- Through-holes for expansion connectors: 6
- USB port connector (Series-B receptacle): 1
- H-UDI port connectors (36-pin/14-pin): 1 each
- Serial port connector (D-sub, 9-pin): 1
- RCAN port connector: 1
LEDs
- Power LED: 1
- User LEDs: 6
Switches
- Reset, NMI, IRQ switches
- System setting DIP switches: 5/package
- User DIP switches: 4/package
Dimensions
- 100 x 160mm
- Mounting form: PCB (4-layer, double-sided)
- Number of board: 1
Other items
- CD-ROM (User's Manual, Installation Manual, and sample program)
- Release note
- Power supply cablePrepare following items (not included in this product)- Power supply: 5V (1.5A min.)- SuperH RISC engine C/C++ Compiler Package- E10A-USB emulator
Exterior (Top view of the component side)Exterior (Top view of the solder side)M3A-HS87G50 Block Diagram
下载连接:
SAM9G45核心板串口接插件封装规格 |
