M3A-HS64G02 是一块可选择的开发板,可以连接到M3A-HS64G50上.The M3A-HS64G50 is suitable for developing the video input and music-playing applications.NoticeThis product does not come with the power supply and the development tools. Prepare the following items before using this optional board.- SH7264 CPU board (M3A-HS64G50)- SuperH RISC engine C/C++ Compiler Package- E10A-USB emulator- LCD moduleThis optional board cannot be connected to the SH7262 CPU board (M3A-HS62G50)Product Information
Part numberOverviewApplicable CPU boardM3A-HS64G02Optional board for graphic displayM3A-HS64G50
Features
| Comes with a video input interface, an audio interface, and an LCD module interface. | | All PWM output pins and timer output pins are inserted into connectors to allowing for automotive meter or brightness-control application development. | | Comes standard with CAN connectors, an IEBus™ connector, IIC connector, and an SD card slot. | Specifications
ItemSpecificationLCD
- Flexible connectors for LCD module: 2 (see note)
- MIL-spec connector for LCD module: 1 (30-pin)
Video signal input
- Composite video pin (RCA connector): 1
- S-video connector : 1
- Video decoder IC (AK8851): 1
Audio
- Stereo pin jack for audio output: 1
- Audio optical connector: 1
- Audio codec for audio output (AK4353): 1
SD card interface
- SD card slot: 1
- Includes a card power control IC
CAN
- CAN connectors: 2
- CAN driver IC (HA13721FP)
IEBus™
- IEBus™ connector : 1
- IEBus™ driver IC (HA12187FP)
UART
- UART connector (TxD, and RxD only): 1
IIC
- MIL-spec connector for connecting an external IIC interface: 1 (20-pin)
Switches
- Key input switches: 16 (4 switches x 4 A/D inputs)
- Interrupt switches: 2
Connectors
- MIL-spec connector for PWM timer output: 1 (20-pin)
- MIL-spec connector for timer output: 1 (20-pin)
LEDs
- LED for timer output check: 14
Dimensions
- 210 x 148 mm
- Mounting form: PCB (4-layer, double-sided)
- Number of boards: 1
Other
- CD-ROM (User's Manual, Installation Manual, and sample program)
- Release Note
- AC adapterPrepare the following items (not included in this product)- SH7264 CPU board (M3A-HS64G50)- SuperH RISC engine C/C++ Compiler Package- E10A-USB emulator- LCD module
Note: A flexible connector for LCD module is for the TX09D14VM3CAA and TX09D55VM1CDA (LCD modules manufactured by Hitachi Displays, Ltd.).When connecting other LCD module, MIL-spec connector for LCD module must be used.Product Appearance
Exterior (Top view of the component side)Exterior (Top view of the solder side)M3A-HS64G02 Block Diagram
