M3A-HS37是一个CPU开发板,装有SH7137 (SH-2 核, 80MHz operating, 100 pin version). Notice | This product does not include power supply and development tools. It is necessary to prepare following items separately.- Power supply (5V, 1.5A, min.)- SuperH RISC engine C/C++ compiler package- E10A-USB | Product Information
CPUPart NumberCPU VoltageCPU mountingSH7137M3A-HS37G503.0 to 3.6V or4.5 to 5.5VMounted on board directly
M3A-HS37 Features
| The M3A-HS37 is a CPU board mounting SH7137 (SH-2 core, 80MHz operating, 100 pin version). | | It is easy for evaluation of on-chip peripheral I/O and system extension. | | All SH7137 I/O port are connected to extension connectors (*1) so that it is possible to develop the extension board for a variety of uses. | | The H-UDI connector (14-pin) to which Renesas emulator E10A-USB (*2)can be connected is mounted on board. | | (*1): Only through holes are available(*2): Optional item | M3A-HS37 Specifications
ItemSpecificationConnector
- H-UDI connector (36-pin / 14-pin)
- RCAN connector(9-pin, D-sub connector)
- Serial port connector (RS-232C, 9-pin, D-sub connector)
- Extension connector *Only through holes are available
LED
- Power LED (1pc.)
- User LED (6 pcs.
Switch
- Reset switch, NMI switch, IRQ2 switch
- System setup DIP switch (4poles, 1 pc.)
- User DIP switch (4poles, 1pc.)
Board Dimensions
- Dimensions: 100mm x 100mm
- Mounting form: 6-layer, double-side mounted
- Board configuration:1 board
Included Accessories
- CD-ROM (User's manual, Installation manual, Sample program)
- Release Note
- Power supply cable*Notice: It is necessary to prepare following items separately (These products are not included)- Power supply (5V, 1.5A min.)- SuperH RISC engine C/C++ compiler package- E10A-USB
M3A-HS37 Appearance
Top View of the Component SideTop View of the Solder Side
下载连接:
M3A-HS37 用户指南 |
