如果与外部SDRAM的连接,它可以在16位和32位总线宽度之间切换。Notice | This product does not include power supply and development tools. It is necessary to prepare following items separately.- Power supply : 5V (1.5A or more)- SuperH RISC engine C/C++ compiler package- E10A-USB | Product Information
CPUType Code of CPU BoardOn-board MemoryCPU MountingSH7203M3A-HS30G50SDRAM (32MB), FLASH Memory (4MB) mountedChip mounted
M3A-HS30G50 Features
| For the connection with an external SDRAM, it can be switched between the 16-bit bus width and 32-bit bus width. | | The board comes standard with the UART, CAN, and USB connector as the SH7203 peripheral function interface. | | The board comes standard with the series A receptacle as the USB connector. | | All the pins of SH7203 data bus, address bus, and peripheral function are connected to the extension connector. | | Mounted the connector which the Renesas Technology on-chip emulator E10A-USB can be connected. | M3A-HS30G50 Specifications
ItemSpecificationCPU
- SH7203- Input (XIN) clock:16.67MHz- Bus clock:66.67MHz, max.- CPU clock:200MHz, max.
- On-chip Memory- RAM:64K-byte (High speed), 16K-byte(For data retention)
External Memory
- Flash memory:4M-byte
- SDRAM:16M-byte (16-bit bus width selected), 32M-byte (32-bit bus width selected)
Connector
- USB connector (Series A receptacle)
- RCAN connector (D-SUB 9-pin x 2)
- Serial port connector (D-SUB 9-pin)
- H-UDI connector (14-pin/36-pin)
- Extension connector (20-pin MIL standard connector x 5, 40-pin MIL standard connector x 2)
LED
- Power LED (1pc.)
- User LED (4 pcs.)
Switch
- Reset switch, NMI switch, IRQ0 switch, Test switch
- DIP switch for system setting (4-pole x 1)
- User DIP switch (4-pole x 1)
Board Dimensions
- Dimensions: 150mm x 100mm
- Mounting form : 6-layer, double-side mounted
- Board configuration:1 board
Included Accessories
- CD-ROM (User's Manual, Installation Manual, Sample Software)
- Release Note
- Power supply cable*Notice: It is necessary to prepare following items separately (These products are not included)- Power supply : 5V (1.5A or more)- C/C++ Compiler package for SuperH RISC engine family- E10A-USB
M3A-HS30G50 Appearance
Top view of the component sideTop view of the solder side |
