M3A-HS19是一个CPU开发板,装有SH7619 (SH-2 核, operating at 125 MHz, 176-pin).Notice | Power supply and development tools are not included in this product. Following items should be prepared by user before using this CPU board.- 5 V DC Power supply (1.5 A min.)- SuperH RISC engine C/C++ compiler package- E10A-USB emulator | Product Information
CPUPart NumberCPU VoltageCPU mountingSDRAMEEPROMFLASH ROMSH7619M3A-HS19G50I/O: 3.3VDCInternal: 1.8VDCMounted on board directlyImplementedImplementedImplemented
M3A-HS19 Features
| M3A-HS19 is a CPU board equipped with SH7619 (SH-2 core, operating at 125 MHz, 176-pin). | | Comes standard with LAN and PC connectors. | | Easy for evaluation of on-chip peripheral I/Os and system extension | | SH7619 bus signals and I/O ports are connected to expansion connectors (*1) to enable to develop the expansion board for variety of use. | | T-Kernel based TCP/IP is available on this board. | | H-UDI connector(14-pin) is provided to connect the Renesas E10A-USB emulator (*2) | | (*1): Through-hole only(*2): Optional item | M3A-HS19 Specifications
ItemSpecificationEthernet
- RJ-45 LAN connector built-in pulse transformer (8-pin,RJ-45)
Connectors/through-hole
- PC card connector (68-pin)
- Serial port connector (RS-232C, 9-pin, D-sub)
- Serial port connector (2-pin,through-hole)
- Serial port connector (RS422, 4-pin, through-hole)
- H-UDI connector (14-pin)
- SH7619 expansion connectors (total 140-pin, through-hole)
LED
- Power LED : 1
- User LEDs : 4
Switch
- Power supply switch, Reset switch, NMI switch, IRQ0 switch
- Mode DIP switches (4/package)
- User DIP switches (4/package)
Dimensions
- Dimensions: 100mm x 100mm (Projection not included)
- CPU mounting: 6-layer, double-sided
- Board configuration: 1 board
Accessories
- CD-ROM- User's Manual (Circuit diagram included)- Installation Manual- Sample program (setting example of bus controller, Ethernet sample program et al.)
- Release Note
- Power supply cable*Notice: Following items should be prepared by user. (Not included in this product)- 5 V DC power supply (1.5 A min.)- SuperH RISC engine C/C++ compiler package- E10A-USB emulator
M3A-HS19 Appearance
Top View of the Component SideTop View of the Solder Side
下载连接:
M3A-HS19 用户指南
M3A- HS19安装手册 |
