查看: 454|回复: 0
M3A-2154G52B入门套件
发表于 2012-9-4 13:38:53 | 显示全部楼层 |阅读模式
入门套件用于32185, 32186, 32192, 32195和 32196 群。有完美的评价和用户培训。Hardware
Evaluation Board
- Includes M32192F8VFP/ M32186F8VFPM32192F8VFP: On-chip 1MB Flash Memory, 176KB RAMM32186F8VFP: On-chip 1MB Flash Memory, 64KB RAM
- Operating FrequencyM32192F8VFP: 160MHz (f(XIN)=20MHz, Multiple-by-8) (Note 1)M32186F8VFP: 80MHz (f(XIN)=10MHz, Multiple-by-8) (Note 1)
- MCU Operation Mode: Single-chip/External Extension/Processor Mode
- LED: 8 (1 port)
- Switch: Port Operation x 8 (1 port)
- Key: Volume key x 2 (A/D converter x 2 channels)Reset Key
- Connector: JTAG Connector (10-pin)NBD Connector (14-pin)RS-232C Connector for Serial I/OCAN ConnectorExternal Extension ConnectorPower Supply Connector
- Power Supply Voltage: 4.75V to 5.25V (0.5A or more)
Software (CD-ROM)
- Debugger front endM3T-PD32RM
- Cross tool kit for M32R FamilyM3T-CC32R (trial version)
Documentation (CD-ROM)You can download the latest version of the following bundled documents from a "documentation" button in the top navigation on this page.
- 32185/32186/32192/32195/32196 Group Starter Kit UESR'S MANUAL M3A-2154G52B
- SFR Definition File
- Sample Program
- Application Note
Hardware
M32192F8VFP (mounted): 160MHz (f(XIN)=20MHz, Multiple-by-8), M32186F8VFP (Included): 80MHz (f(XIN)=10MHz, Multiple-by-8), 4.75V to 5.25V (0.5A or more)Height : Approx. 2.2cmWidth : Approx. 10cmDepth : Approx.17cmPC System Requirements
  • IBM PC/AT or compatible PC
  • Pentium III 500MHz or higher recommended
  • Memory 192MB or higher recommended
  • Microsoft Windows 98/Windows Me/Windows 2000/Windows XP
  • 1 USB port
下载连接:
M3A-2154G52B用户指南
GMT+8, 2024-11-26 22:47 , Processed in 0.123028 second(s), 15 queries , MemCache On.
