M32176F4VFP评估板有 512-Kbyte 闪存 。M3A-2152G52A Includes
- 32176 Group Evaluation board (with maximum 512-Kbyte flash memory)
- Compact emulator (M32100T-EZ-E*1) [Limited version for using only 32176 group MCU]
- Debugger front end (M3T-PD32RM)
- Cross tool kit for the M32R Family (M3T-CC32R) [trial version]
- SFR Header file, Sample program
Features
- The evaluation board mounts M32176F4VFP with 512-Kbyte flash memory by IC socket.
- Free from restrictions on MCU resources (ROM, RAM or I/O) during evaluation via on-board debugger by SDI
- The evaluation board comes with extension connectors for all ports except those used for power supply and MCU control
- Includes dedicated debugger front end accommodating M3T-PD32R (emulator debugger for M32100T-SDI-E) to GUI operation system
- The evaluation board can operate stand-alone after programming flash memory
32176 Group Evaluation Board
Board Specification | Mounted MCU | M32176F4VFP | System clock | 40MHz (f(XIN)=10MHz, multiple-by-4) | MCU operation mode | Single-chip / External extension / Processor | MCU internal memory | Flash memory: 512KBSRAM: 24KB | Input/Output function | LED x 8: 1 portToggle switch x 8:1 portVR control x 2: A-D converter (2 channels)Reset switch | Connector | Communication connector for compact emulator (10 pins)RS-232C connector for serial communicationCAN communication connectorMCU functional evaluation connector*Power supply connector | Power supply | 3.0V to 3.6V or 4.75V to 5.25V (0.5A or more) | Operating Environment (required on the user side)
(1) Recommended Host PCHost Machine | IBM PC/AT compatibles | CPU | Pentium 3 500MHz or higher CPU is recommended. | Memory | 192Mbytes or more system memory is recommended. | OS | Windows 98, 2000, XP, Me | (2) Power supply (5V/1A) Example of System Configuration
下载连接:
M3A-2152G52A用户指南 |
