查看: 298|回复: 0
M32R/ECU功能扩展板入门套件
发表于 2012-9-4 13:18:09 | 显示全部楼层 |阅读模式
M3A-2142G03是一个 M32R/ECU引脚处理板入门套件。It carries out a pin processing for MCU mounted on the evaluation board for starter kit by connecting it to the evaluation board. Features
  • Comes with check-pins (for extension connectors) to all ports of MCU mounted on evaluation board for M32R/ECU starter kit.
  • Comes with 5 channels for UART communication as RS-232C I/F.
  • Comes with check-pins for RTD signals as RTD I/F.
Board Specification
Board SpecificationCheck-pinUsed to monitor and set the signal from extension connector
ConnectorRS-232C connectors for serial communication: 5 channelsExtension connector (Connectable to the evaluation board for starter kit)RTD* Monitor tool connector (through-holes only) Power supply connector
Power supply3.0V to 3.6V or 4.75V to 5.25V (0.5A or more)
  Operating Environment (required on the user side)
(1) Recommended Host PC
Host MachineIBM PC/AT compatibles
CPUPentium 3 500MHz or higher CPU is recommended.
Memory192Mbytes or more system memory is recommended.
OSWindows 98, 2000, XP, Windows Me
(2) M32R/ECU starter kit board(3)Power supply (5V/1.5A when the evaluation board for starter kit in operation)
GMT+8, 2024-11-26 22:30 , Processed in 0.104188 second(s), 15 queries , MemCache On.
