查看: 296|回复: 0
R8A66597FP多功能开发板 M3A-0040
发表于 2012-9-4 11:47:48 | 显示全部楼层 |阅读模式
USB通信多功能开发板包含 R8A66597FP和可控的D+/D-线阻抗匹配。Features two built-in PCB connectors (25-pin x 2-line) for a MCU board and split bus connections. Also equipped with 24MHz quartz-crystal oscillator, USB connector, test pin, bus mode selection switch and interface power supply change jumper switch.
下载连接:
M3A-0040使用手册
GMT+8, 2024-11-26 22:44 , Processed in 0.119769 second(s), 15 queries , MemCache On.
