查看: 318|回复: 0
M66592FP多功能开发板M3A-0038G01
发表于 2012-9-4 11:38:12 | 显示全部楼层 |阅读模式
USB通信多功能开发板包含M66592FP和可控的D+/D-线阻抗匹配。Features two built-in PCB connectors (25-pin x 2-line) for a MCU board and split bus connections. These connectors are upward compatible with the M3A-0032 and M3A-0037G01 are easily connectable to systems developed for the M66291 or the M66591. Also equipped with 24MHz quartz-crystal oscillator, USB connector, test pin, bus mode selection switch and interface power supply change jumper switch. Specifications
  • Board size: 70 mm X 80 mm
  • Supply power VDD (1.5 V), VIF (3.3 V or 1.8 V)
  • Oscillation Frequency: f(XIN) = 24 MHz
  • Interface: 50-pin Connector X 2
  • possible to select separate bus mode or multiplex bus mode for M66592FP.
下载连接:
M3A-0038G01使用说明书
GMT+8, 2024-11-26 22:31 , Processed in 0.117082 second(s), 15 queries , MemCache On.
