该开发板是将14引脚 E8a (或E8)仿真器转换成10引脚。When using this product, make sure that the pin assignment of the target system is the same as the following connector pin assignment. It can be used only when the pin assignment of the 10-pin connector-side is the same.E8a (or the E8) emulator software and Flash development Toolkit can be used for this product. Target Devices
Family | Series | Group | M16C | M16C/Tiny | M16C/26 | M16C/26A | M16C/28 | M16C/29 | M16C/60 | M16C/62P | M16C/6N4, M16C/6N5 | M16C/6NK, M16C/6NL, M16C/6NM, M16C/6NN | M32C/80 | M32C/84 | M32C/85 | M32C/86 | M32C/87 | M32C/88 | * R8C Family is not supported.
Pin Assignment
Connector pin assignments of this product are shown below.
- 14PIN Connector [J1] (Manufacturer: Omron, Part Number: XG4C-1434)
- 10PIN Connector [J2] (Manufacturer: Omron, Part Number: XG4H-1031)
14PIN Connector [J1] Pin Assignment | 10PIN Connector [J2] Pin Assignment | Pin No. | Signal | Pin No. | Signal | 1 | SCLK | 1 | Vcc | 2 | GND | 2 | BUSY | 3 | CNVss | 3 | SCLK | 4 | EPM (RP) | 4 | RxD | 5 | TxD | 5 | CE (P1_6) | 6 | N.C | 6 | EPM (RP) | 7 | CE (P1_6) | 7 | GND | 8 | Vcc | 8 | RESET | 9 | BUSY | 9 | CNVss | 10 | N.C | 10 | TxD | 11 | RxD | - | - | 12 | N.C | 13 | RESET | 14 | GND | Connection Example
