查看: 1379|回复: 0
H8SX/1622F入门套件
发表于 2012-9-3 14:40:50 | 显示全部楼层 |阅读模式
H8SX/1622F入门套件是易于操作的 H8SX/1622F微控制器入门和评估工具。The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E10A emulator.The Renesas Starter Kit for H8SX/1622F may be connected to the host PC using a simple RS232 serial connection or via the included USB E10A on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools. LED[/td][td]Power indicator: green × 1[/td][/tr][tr][td]Boot indicator: orange × 1[/td][/tr][tr][td]User: green × 1, orange × 1, red × 2[/td][/tr][tr][td=1,3]Switch[/td][td]Reset × 1[/td][/tr][tr][td]User/Boot × 1[/td][/tr][tr][td]User × 2[/td][/tr][tr][td=1,2]ΔΣ ADC Port[/td][td]Single-ended input: 1 channel[/td][/tr][tr][td]Differential input: 1 channel[/td][/tr][tr][td=1,2]DC Power Jack[/td][td]Board: 5 V Input[/td][/tr][tr][td]ΔΣ ADC: 5 V Input[/td][/tr][tr][td]E10A Header[/td][td]14-pin box header[/td][/tr][tr][td]E8 Header[/td][td]14-pin box header[/td][/tr][tr][td]RS232 Serial Connector[/td][td]9-pin DSUB[/td][/tr][tr][td]LCD Display Connector[/td][td]14-pin socket[/td][/tr][tr][td]Microcontroller Pin Header[/td][td]2.54 mm pitch, 36-pin × 4[/td][/tr][tr][td]Application Board Interface[/td][td]2.54 mm pitch, 26-pin × 2 (JA1, JA2), 24-pin × 2 (JA5, JA6)[/td][/tr][tr][td]BUS Interface Option[/td][td]2.54 mm pitch, 50-pin[/td][/tr][/table]* Microcontroller Pin Header, Application Board Interface and BUS Interface Option are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer)
<a name="config">Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E10A-USB for Starter Kit
  • Connection Cable (USB Cable, User Interface Cable)
  • Multi region 5 V power supply
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C/C++ Compiler: C/C++ Compiler Package for H8SX, H8S, H8 Families Evaluation Version- Debugger: E10A-USB Emulator Debugger
下载连接:
H8SX/1622F入门套件用户指南
H8SX/1622F入门套件指导手册
H8SX/1622F入门套件快速入门手册
GMT+8, 2024-11-26 23:41 , Processed in 0.122116 second(s), 15 queries , MemCache On.
