查看: 1341|回复: 0
M32C/87入门套件
发表于 2012-9-3 14:16:23 | 显示全部楼层 |阅读模式
M32C/87入门套件是易于操作的M32C/87微控制器入门和评估工具。 The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E8a emulator and/or Flash Development Toolkit.The Renesas Starter Kit for M32C/87 may be connected to the host PC using a simple RS232 serial connection (not normally fitted) or via the included USB E8a on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.Note
If you wish to use the Renesas Starter Kit for M32C/87 with the Renesas Starter Kit Ethernet & USB Application Board please contact your regular Renesas Tools supplier for further information as some modifications may be required to your Renesas Starter Kit. Block Diagram
Layout and Specification
The LCD display module is supplied as a detachable sub-board. The board dimensions are 120 mm by 100 mm, detailed dimensions are available in the user manual.ItemSpecificationMicrocontrollerM30879FLGPInput ClockMain: 10 MHzSub: 32.768 kHzPotentiometerSingle-turn, 10 kΩLEDPower indicator: green x 1Boot indicator: orange x 1User: green x 1, orange x 1, red x 2SwitchReset x 1User/Boot x 1User x 2DC Power Jack5 V InputE8a Header14-pin box headerRS232 Serial Connector9-pin DSUBLCD Display Connector14-pin socketCAN Connector2.54 mm pitch, 3-pin x 2 (CAN BUS line x 2, Ground x 1)Microcontroller Pin Header2.54 mm pitch, 30-pin x 2 (J1, J3), 20-pin x 2 (J2, J4)Application Board Interface2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)BUS Interface Option2.54 mm pitch, 50-pin* RS232 Serial Connector, CAN Connector, Microcontroller Pin Header, Application Board Interface and BUS Interface Option are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer)Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E8a Emulator
  • Connection Cable (USB Cable, User Interface Cable)
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C Compiler: M3T-NC308WA Evaluation Version- Debugger: E8a Emulator Debugger- Flash Memory Programmer: Flash Development Toolkit Evaluation Version
下载连接:
M32C/87入门套件指导手册
M32C/87入门套件用户手册
M32C/87入门套件快速入门指南
GMT+8, 2024-11-26 23:21 , Processed in 0.115946 second(s), 15 queries , MemCache On.
