查看: 1528|回复: 0
R8C/LA8A入门套件
发表于 2012-9-3 13:38:33 | 显示全部楼层 |阅读模式
R8C/LA8A 入门套件是易于操作的R8C/LA8A 微控制器入门和评估工具。The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E8a emulator and/or Flash Development Toolkit.The Renesas Starter Kit for R8C/LA8A may be connected to the host PC using a simple RS232 serial connection or via the included USB E8a on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools. Input Clock[/td][td]Main: 20 MHz[/td][/tr][tr][td]Sub: 32.768 kHz[/td][/tr][tr][td]Potentiometer[/td][td]Single-turn, 10 kΩ[/td][/tr][tr][td=1,2]LED[/td][td]Power indicator: green x 1[/td][/tr][tr][td]User: green x 1, orange x 1, red x 2[/td][/tr][tr][td=1,2]Switch[/td][td]Reset x 1[/td][/tr][tr][td]User x 3[/td][/tr][tr][td]DC Power Jack[/td][td]5 V Input[/td][/tr][tr][td]E8a Header[/td][td]14-pin box header[/td][/tr][tr][td]RS232 Serial Connector[/td][td]9-pin DSUB[/td][/tr][tr][td]LCD Display Connector[/td][td]14-pin socket[/td][/tr][tr][td]LCD Panel Connector[/td][td]50-pin socket (JA4)[/td][/tr][tr][td]Microcontroller Pin Header[/td][td]2.54 mm pitch, 36-pin x 4 (J1 to J4)[/td][/tr][tr][td]Application Board Interface[/td][td]2.54 mm pitch, 26-pin (JA1, JA2), 24-pin (JA5, JA6)[/td][/tr][/table]* Microcontroller Pin Header and Application Board Interface are not contained in the product.<a name="config">Configuration
  • CPU Board
  • Detachable LCD Application Board V2
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E8a Emulator
  • Connection Cable (USB Cable, User Interface Cable)
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C Compiler: M3T-NC30WA Evaluation Version- Debugger: E8a Emulator Debugger- Flash Memory Programmer: Flash Development Toolkit Evaluation Version
下载连接:
R8C/LA8A入门套件用户指南
R8C/LA8A入门套件指导手册
R8C/LA8A入门套件快速入门指南
GMT+8, 2024-11-26 23:34 , Processed in 0.104375 second(s), 15 queries , MemCache On.
