查看: 1428|回复: 0
R8C/25入门套件
发表于 2012-9-3 10:35:50 | 显示全部楼层 |阅读模式
R8C/25入门套件是易于操作的R8C/25微控制器入门和评估工具。The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E8a emulator and/or Flash Development Toolkit.The Renesas Starter Kit for R8C/25 may be connected to the host PC using a simple RS232 serial connection (not normally fitted) or via the included USB E8a on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.Input Clock[/td][td]Main: 20 MHz[/td][/tr][tr][td]Sub: 32.768 kHz[/td][/tr][tr][td]Potentiometer[/td][td]Single-turn, 10 kΩ[/td][/tr][tr][td=1,3]LED[/td][td]Power indicator: green x 1[/td][/tr][tr][td]Boot indicator: orange x 1[/td][/tr][tr][td]User: green x 1, orange x 1, red x 2[/td][/tr][tr][td=1,3]Switch[/td][td]Reset x 1[/td][/tr][tr][td]User/Boot x 1[/td][/tr][tr][td]User x 2[/td][/tr][tr][td]DC Power Jack[/td][td]3 V to 5 V Input[/td][/tr][tr][td]E8a Header[/td][td]14-pin box header[/td][/tr][tr][td]RS232 Serial Connector[/td][td]9-pin DSUB[/td][/tr][tr][td]LCD Display Connector[/td][td]14-pin socket[/td][/tr][tr][td]LIN Connector[/td][td]2.54 mm pitch, 3-pin (VBAT x 1, LIN Bus Line x 1, Ground x 1)[/td][/tr][tr][td]Microcontroller Pin Header[/td][td]2.54 mm pitch, 14-pin x 4[/td][/tr][tr][td]Application Board Interface[/td][td]2.54 mm pitch, 26-pin x 2[/td][/tr][/table]* RS232 Serial Connector, LIN Connector, Power Connector (for LIN), Microcontroller Pin Headerand Application Board Interface are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer)
<a name="config">Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E8a Emulator
  • Connection Cable (USB Cable, User Interface Cable)
  • Quick Start Guide
  • CD-ROM - Documents : User Manual, Tutorial, and more- IDE : High-performance Embedded Workshop- C Compiler : M3T-NC30WA Evaluation Version- Debugger : E8a Emulator Debugger- Flash Memory Programmer : Flash Development Toolkit Evaluation Version
下载连接:
R8C/25入门套件用户指南
R8C/25入门套件指导手册
R8C/25入门套件快速入门指南
GMT+8, 2024-11-26 23:27 , Processed in 0.099185 second(s), 15 queries , MemCache On.
