R8C/23入门套件是易于操作的 R8C/23微控制器入门和评估工具。The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E8a emulator and/or Flash Development Toolkit.The Renesas Starter Kit for R8C/23 may be connected to the host PC using a simple RS232 serial connection (not normally fitted) or via the included USB E8a on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools. Block Diagram
Layout and Specification
The LCD display module is supplied as a detachable sub-board. The board dimensions are 85 mm by 100 mm, detailed dimensions are available in the user manual.ItemSpecificationMicrocontrollerR5F21237JFPInput Clock20 MHzPotentiometerSingle-turn, 10 kΩLEDPower indicator: green x 1Boot indicator: orange x 1User: green x 1, orange x 1, red x 2SwitchReset x 1User/Boot x 1User x 2DC Power Jack3 V to 5 V InputE8a Header14-pin box headerRS232 Serial Connector9-pin DSUBLCD Display Connector14-pin SocketLIN Connector2.54 mm pitch, 3-pin (VBAT x 1, LIN Bus Line x 1, Ground x 1)CAN Connector2.54 mm pitch, 3-pin (CANN Bus Line x 2, Ground x 1)Microcontroller Pin Header2.54 mm pitch, 14-pin x 4Application Board Interface2.54 mm pitch, 26-pin x 2* RS232 Serial Connector, LIN Connector, Power Connector (for LIN), CAN Connector,Microcontroller Pin Header and Application Board Interface are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer)
Configuration
- CPU Board
- Detachable LCD Display Module
- Detachable AD Adjustment Shaft
- E8a Emulator
- Connection Cable (USB Cable, User Interface Cable)
- Quick Start Guide
- CD-ROM- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C Compiler: M3T-NC30WA Evaluation Version- Debugger: E8a Emulator Debugger- Flash Memory Programmer: Flash Development Toolkit Evaluation Version
下载连接:
R8C/23入门套件用户指南
R8C/23入门套件指导手册
R8C/23入门套件快速入门指南 |
