查看: 1337|回复: 0
SH7216 入门套件
发表于 2012-9-3 09:02:25 | 显示全部楼层 |阅读模式
SH7216入门套件在加速代码开发和减少上市时间上已经成熟。An Renesas Starter Kit+, as the name suggests, is a complete development kit for Renesas microcontrollers. Input Clock[/td][td]Main: 12.5 MHz[/td][/tr][tr][td]USB: 48 MHz[/td][/tr][tr][td]Ethernet (for PHY): 25 MHz[/td][/tr][tr][td]Potentiometer[/td][td]Single-turn, 10 kΩ[/td][/tr][tr][td=1,3]LED[/td][td]Power indicator: green x 1[/td][/tr][tr][td]Ethernet indicator: yellow x 5[/td][/tr][tr][td]User: green x 1, yellow x 1, orange x 1, red x 3[/td][/tr][tr][td=1,2]Switch[/td][td]Reset x 1[/td][/tr][tr][td]User x 3[/td][/tr][tr][td]DIP Switch[/td][td]4-pole x 2, 6-pole x 1[/td][/tr][tr][td]DC Power Jack[/td][td]5 V Input[/td][/tr][tr][td=1,2]E10A-USB Header[/td][td]Without AUD Function: 14-pin box header[/td][/tr][tr][td]With AUD Function: 36-pin, Mini-D Ribbon Connector, Right angle[/td][/tr][tr][td]RS232 Serial Connector[/td][td]9-pin DSUB[/td][/tr][tr][td]LCD Display Connector[/td][td]14-pin socket[/td][/tr][tr][td]USB Connector[/td][td]Socket-B[/td][/tr][tr][td]RCAN Connector[/td][td]2.54 mm pitch, 3-pin (CAN Bus line x 2, Ground x 1)[/td][/tr][tr][td]Ethernet Connector[/td][td]RJ45[/td][/tr][tr][td]Extension Header[/td][td]26-pin (JN1, JN2, JN5, JN6), 50-pin (JN3)[/td][/tr][/table]* The position and the function assignment of JN1-JN6 differs from that of Extension Board Interface JA1-JA6 of other RSK products.
<a name="config">Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E10A-USB for Starter Kit
  • Connection Cable (USB Cable, User Interface Cable)
  • Multi region 5 V power supply
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial and more- IDE: High-performance Embedded Workshop- C/C++ Compiler: C/C++ Compiler Package for SuperH Family Evaluation Version- Debugger: E10A-USB Emulator Debugger
Notes
  • E10A-USB for Starter Kit is a special emulator for only Renesas Starter Kit+ products.
  • The C/C++ Compiler Package for SuperH Family Evaluation Version does not come with technical support services. In addition, the C/C++ Compiler Package for SuperH Family Evaluation Version has some restrictions compared to the Product Version.Trial period: 60 daysThe link size will be limited to 256 KB after 60 days
PC System Requirements
  • IBM PC/AT or compatible PC (USB interface necessary) *1
  • Intel Pentium III 600 MHz or higher *3
  • Memory 128 MB or higher
  • Microsoft Windows 2000/ Windows XP/Windows Vista *2
下载连接:
SH7216入门套件用户指南
SH7216入门套件指导手册
SH7216入门套件快速入门指南
GMT+8, 2024-11-26 23:15 , Processed in 0.118950 second(s), 15 queries , MemCache On.
